Forums >> Revit Building >> Technical Support >> terminating some but not all rails at end posts
Wed, Oct 27, 2010 at 11:04:52 AM | terminating some but not all rails at end posts
lizarch5
I have a residential deck railing I am trying to model with a top and bottom rail (vertical 2x4's) spanning between 4x4 corner and end posts. The top and bottom rail are used for attaching 2x2 balusters, and then a cap rail sits on top of the posts. I have positioned the end posts using the "spacing" variable so that the cap rail will extend a little past the end posts, but unfortunately the top and bottom rail also project through the end posts. Is there any way to truncate the top and bottom rail at the end posts without also truncating the cap rail? I've looked at other forum posts and can't seem to find a discussion of this issue, though I have struggled with it before and it seems like it should be a common issue.
Wed, Oct 27, 2010 at 11:39:49 AM | terminating some but not all rails at end posts
Use two railings in the same place and stop the appropriate one at the post - it will not have the cap rfail.  The other will be cap rail only ... or as you need it to be.
Wed, Oct 27, 2010 at 12:06:33 PM | terminating some but not all rails at end posts
lizarch5
Thanks for responding.  This should work - an ugly process, but as long as the result looks good . . .
Handrail and guardrail control at end of ramps and stairs.
Fri, Feb 19, 2010 at 11:17:43 AM
intermediate posts in railings
Tue, Oct 12, 2021 at 12:27:49 PM
stair newel post does not go to treads
Mon, Sep 19, 2011 at 1:50:15 PM
railing at post issue
Fri, May 22, 2009 at 9:40:40 AM
Triming the railing on a perpendicular baulster?
Wed, Mar 28, 2007 at 12:30:55 AM
Page generation time: 1.2328
