25 Users Online (23 Members):
Forums >> Revit Systems >> Technical Support >> Change pipe type of entire pipe run?
2 Posts No Rating |
Is there a way to change a pipe type of an entire run? I have a run of pipes that I created on a Hot Water Supply pipe type. I made a branch run off that line that I accidentally had on a Hot Water Return pipe type. Can I change the pipe type of the whole branch at once? I tried selecting the whole branch but since it has a combination of fittings and pipes it won't let me change the type.
When your entire branch is selected look for your Filter button to refine your selection (pipe only) then do it again and select fittings. hth
Gary |
Pipe Accessories and Pipe Type parameter |
Tue, Dec 27, 2011 at 11:25:39 AM
Trim HSS Round pipe into another HSS Round pipe |
Tue, Apr 3, 2012 at 4:39:45 AM
pipe dimensions |
Wed, Dec 2, 2015 at 7:47:03 AM
Pipe Sizes |
Thu, Jan 22, 2009 at 5:56:11 PM
Changing Pipe System |
Thu, Dec 23, 2021 at 8:48:08 AM
