Forums >> Revit Structure >> Technical Support >> Rebar Toggle
Wed, Oct 27, 2010 at 9:06:53 AM | Rebar Toggle
gdoherty0102
3 Stars: 2 Votes
Ok, so I have many sets of rebar in a foundation wall elevation and none/most of them will not allow me to use the grips to change the parameters of the rebar set in the elevation...ie the length on either side, or the extents of the set.  Each set of bars has 4 toggles 2 extend the length of the bars and 2 change the extents of the set which will vary spacing and number of bars in the set.
So as I said, this elevation will not allow me to use the grips, I can cut a section or go to a plan and use the grips just find, but in elevation I can not...any one have and suggestions?  Other than using sections and plans.
How to apply the rebar in a ramp.
Mon, Jul 5, 2010 at 4:53:04 AM
Need help to modify rebar bar size!!!!!
Thu, Apr 6, 2017 at 3:03:05 AM
Revit 2016 - Rebar note
Wed, Jul 29, 2015 at 9:21:12 AM
How to delete rebar?
Tue, May 26, 2020 at 5:25:50 AM
Rebar Schedule - Right click to Show rebar in View - I see no "Show... " option
Sat, Nov 22, 2014 at 3:28:11 PM
Page generation time: 0.1754
