25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> View Range does not show Existing / Demolition / New correctly
2 Posts No Rating |
I have an issue where I have extended a second floor plan's view range down to show some "eyebrows" over lower windows. I used the "View Depth" parameter. Part of the eyebrow is existing, part is demolished and part is new. But the graphic style of those objects appears "New" in all cases. I can't locate a separate setting for display for the "View Depth" entities, so I believe this is a bug. Any ideas? Revised to add: Revit 2011 without Product Update #2. Edited on: Tue, Oct 26, 2010 at 6:42:42 PM
Edited on: Wed, Oct 27, 2010 at 1:43:17 PM
I think you need to look again at all the entities and look at your view settings. Also look at what might be hiding what. If new and existing demolished occupy the same location, that would be a problem.
2 Posts No Rating |
OK. I don't know why Revit is designed this way, but here's what I see. If I set my "View Range" Top: 10' Cut: 3' Bottom: 0' View Depth Level: -3' Then everything below "Bottom" will not show phasing, it will all show as "New" or "Complete". If I change "Bottom" to match "View Depth" (-3' in the example), then phasing will be shown. For Ceiling Plans, "Top" and "View Depth" must match for phasing to be shown.
Edited on: Wed, Oct 27, 2010 at 1:49:09 PM
Phasing and Room Tag |
Wed, May 26, 2010 at 9:47:45 AM
View Range |
Thu, Oct 24, 2013 at 2:37:43 PM
Existing Wall detail in Section View |
Mon, Jul 21, 2008 at 11:38:46 AM
Phasing - showing all phases in a view |
Wed, Feb 1, 2012 at 9:13:14 AM
low wall not displaying correctly with view range |
Fri, Aug 3, 2012 at 4:35:37 PM
