14 Users Online (12 Members):
Forums >> Revit Structure >> Technical Support >> TAG A COLUMN THAT HAS BEEN MODELED IN PLACE
Hello I have some cranked columns that i modeled in place (swept a profile along a cranked path) Is there anyway i can 'tag' these in the same way as i can with standard columns so that they get a column tag and appear in the column schedule?
Did you set this model to the column category? Did you add the correct shared parameters to it for tagging?
thanks for the reply. I did model it as a column in the catagory, i donm't think i did add the shared parameters you mention. can you point me in the direction of where i would do this?
Did you set the category as "Column" or "Structural Column"? I don't think you'll need to add any parameters if it's a structural column.
I fear i might have set it as 'column' rather than structural column. is there any way i can change the usage of the model in place once it has been drawn?
Yes. "Family Caragory and Parameters" will let you pick a new category. In 2011 it's on the home tab, left end of the ribbon. 2010, it's on the right end of the ribbon. In either case, it's next to the Family Types tool.
Cannot tag a door that has been modeled in place. |
Wed, Nov 2, 2011 at 1:19:40 PM
slanted model in place column |
Sun, Nov 7, 2010 at 9:01:37 PM
COLUMN BASE ELEVATION - TAG |
Tue, Dec 2, 2014 at 1:25:37 PM
Column Volume in Tag |
Tue, Oct 4, 2011 at 1:53:31 PM
Tagging Graphical Column Schedule |
Wed, Nov 24, 2010 at 8:41:14 PM
