18 Users Online (16 Members):
Forums >> Revit Building >> Technical Support >> slanted wall in elevation
15 Posts No Rating |
how do i draw a wall at a slant in elevation? (ie not 90 degrees level-level)
Use "Create" - "Wall" to make an in place family using "Solid Blend" - offset the top sketch from the bottom sketch.
Create a mass that gives you the surface you require, then use wall by face (providing your are using 8.1)
This way you can still have layers to your wall.
thank you for your tips!
17 Posts No Rating |
mr. spot -- If I'm using Revit 2010, do I create a Mass In-place, or create one from the template? Because I tried creating a mass on plan (just playing around with it) and it didn't work. It came out as a flat object with no height. Forgive me, I'm not very good with the mass-modeling. W
So, I've managed to model a wall under COMPONENTS (HOME) and by MODELING IN PLACE. Is there a way I can give this wall the same properties (like structural usage) as my other walls, and can I assign a Wall Type to it? Thanks!
Mr. Spot gave you the options in his earlier post. If you want full wall properties then use the mass to create a face then use wall by face using one of your wall types.... Then you can get rid of the mass or hide it someway so that you can modify later.
Curtain Wall in a Slanted Wall? |
Wed, Aug 8, 2012 at 9:17:56 AM
Slanted curtain wall help! (pic attached) |
Wed, Oct 22, 2014 at 6:02:39 PM
opening in slanted curved wall |
Mon, Sep 29, 2008 at 10:32:57 AM
section in slanted wall |
Mon, Mar 4, 2013 at 3:12:20 AM
Slanted wall |
Wed, Sep 12, 2012 at 11:59:38 AM
