Forums >> Revit Building >> Technical Support >> Room tag callout says room "not enclosed"
Sun, Oct 24, 2010 at 9:50:41 AM | Room tag warning note says "Room is not in a properly enclosed region"
stkarch
these rooms where tagged before...
I needed to re-design and move the rooms around and I moved the tags with there boxed areas out to the side.
Now when I wanted to re-bring them into position a warning note says "Room is not in a properly enclosed region"
I erased them all and try re-tagging, no luck.
I closed the drawing and re-opened...stricke two...
any suggestions?
Edited on: Sun, Oct 24, 2010 at 10:00:34 AM
Edited on: Sun, Oct 24, 2010 at 10:33:38 AM
Mon, Oct 25, 2010 at 7:12:40 AM | Room tag callout says room "not enclosed"
Several things to consider:
  1. Rooms can be created without bounding elements but when that happens, you get your error message.
  2. Rooms must exist and be on in order to be tagged
  3. If you delete a room, the room definition still exists.  To delte this, create a schedule and delete this room definition there.
  4. If rooms exist, but you don't know where they are, you have a few options.
  • Delete the room from the room schedule
  • In the schedule, hover over the room and select show
  • in a plan, select tag all using the room tag
Room tag not showing in only one room. [ 1 2 ]
Sat, Sep 27, 2025 at 3:40:00 AM
15
"TO ROOM / FROM ROOM" DOOR SCHEDULE DISCREPANCY
Wed, Nov 9, 2011 at 5:35:20 PM
Room tag problems
Sun, Aug 24, 2008 at 12:19:37 AM
Help. I forgot how I "turned off" the room tags.
Tue, Oct 8, 2013 at 7:18:18 AM
11
Using Room Tag Family Parameters in a Celing Tag Family
Mon, Sep 22, 2008 at 7:52:40 AM
Page generation time: 1.0640
