Forums >> Revit Building >> Technical Support >> Paint Help
Sat, Oct 23, 2010 at 9:33:06 PM | Paint Help
DERRICK88ROSE
I am trying to add two different colors of paint to two separate walls.  When i go to change the color it changes the color of the previous painted wall.  Is there a way to make more than one paint color?
Sun, Oct 24, 2010 at 5:23:54 AM | Paint Help
JeroentjeM
First select the wall of which you like to change its material.
Sun, Oct 24, 2010 at 7:58:19 AM | Paint Help
Every material in Revit has to be assigned its own unique name, so duplicate your paint, name it like paint-blue, assign blue paint to it and then use that material on your wall.
Sun, Oct 24, 2010 at 9:34:29 PM | Paint Help
DERRICK88ROSE
Duplicating the paint isn't an option for me.  Is there a certain way you do it?
Mon, Oct 25, 2010 at 5:25:08 AM | DERRICK88ROSE
gebber
gebber Avatar
5 Stars: 4 Votes
Quoting DERRICK88ROSE from 2010-10-24 21:34:29
"Duplicating the paint isn't an option for me.  Is there a certain way you do it?"
Weird answer, why would this not be an option.
What are you doing?
You have 2 walls, you have 2 paint colors (materials)
choose paint,
select collor 1 and click(paint) wall 1
choose color 2 and click(paint) wall 2
they should be 2 diferent colors unless 1&2 are the same color or wall.
Mon, Oct 25, 2010 at 7:26:05 AM | Paint Help
Yes, duplicate is available:  Look at the attached.
Mon, Oct 25, 2010 at 10:20:35 PM | Paint Help
DERRICK88ROSE
Thanks WWHub, that diagram helped a bunch.  I was trying to duplicate through type properties and I now understand where to duplicate materials! Thanks again
Wed, May 22, 2013 at 5:33:21 PM | Paint Help
rrbryce
I am using revit 2014. Having trouble painting existing walls. Can someone left foot right foot me through the workaround. Thanks in advance Bob
Thu, May 23, 2013 at 6:19:10 AM | rrbryce
coreed
coreed Avatar
4 Stars: 16 Votes
Quoting rrbryce from 2013-05-22 17:33:21
"I am using revit 2014. Having trouble painting existing walls. Can someone left foot right foot me through the workaround. Thanks in advance Bob"
What do you mean by workaround?
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
How do you tell what finish has been applied with Paint?
Sat, Jan 26, 2013 at 5:14:41 AM
Remove Paint from Walls
Wed, Feb 9, 2011 at 1:33:46 PM
Generic Model (How to Paint or apply materials)
Wed, Oct 9, 2013 at 12:09:40 PM
Changing Wall Paint color
Sun, Feb 7, 2010 at 7:02:40 PM
Paint phasing work around ?
Mon, Jun 1, 2009 at 2:41:15 PM
Page generation time: 0.6736
