Forums >> General Discussion >> Revit Project Management >> Floor Objects Section Graphics
Sat, Oct 23, 2010 at 1:33:53 PM | Floor Objects Section Graphics
pking
I have a concrete slab that is the roof over a below grade lab space. The floor object includes the structural  concrete  slab,  rigid insulation, and a concrete walking surface. The slab has been modified using modify sub elements so that it slopes in two directions.
The trouble I am having is that when the slab in cut in one direction for detail views, the floor material layers are visible. When I cut a section at 90 deg to  that view, I do not see the material layers, I see the entire section shown as concrete. This is not an issue of detail level, the layers are not visible when the visibility is set to fine.
The attached screen shots show  two views of the slab. The first shows all the material layers. The second is the same section view, duplicated and rotated 90 deg, and the material layers are not visible. No settings for the view were changed between these two views.
 I am guessing that this has something to do with the fact that the slab has been modified so that the corners are set to different elevations.
If anyone has any thoughts about the cause or fix, please post.
Thanks
Sun, Oct 24, 2010 at 8:03:44 AM | Floor Objects Section Graphics
Check your detail level.
Sun, Oct 24, 2010 at 10:18:30 AM | Floor Objects Section Graphics
pking
The detail level is the same in both views. The two posted images were the from a section that was copied and rotated 90 deg, so all the settings are the same. Interestingly, if I rotate the section 45 deg, I am able to see all the material layers.
Selecting Objects on floor below
Thu, Nov 29, 2012 at 2:54:55 PM
Intersected objects' materials in section view?
Thu, Apr 1, 2010 at 7:31:56 AM
Missing Section Tag
Fri, Apr 18, 2008 at 9:07:37 AM
Section View with missing objects at certain height!
Tue, Mar 10, 2009 at 10:41:04 PM
My section cut symbols don't show on the floor plans
Thu, Apr 10, 2008 at 8:08:11 PM
Page generation time: 0.5392
