Forums >> Revit Structure >> Technical Support >> How can I radius my coping of steel beams?
Fri, Oct 22, 2010 at 3:16:11 PM | How can I radius my coping of steel beams?
Lonzo
Let me start off by saying I like the coping tool, but I don't see any way to radius the web cope... it is cut at a 90° angle.
Does anyone have any tips? Hints? Secrets?
This is my first ever post to the forum, so please take it easy on the newbie.
I'm using Revit Structure 2010.
Thanks a bunch!Lonzo
Fri, Oct 22, 2010 at 3:36:42 PM | How can I radius my coping of steel beams?
Lonzo
OK, I just checked out www.augi.com and on their "wish list for Revit Structure 2011" is the ability to show a radius cope on steel beams.
If anyone knows of a fix, let me know... until then, I reckon I'll draw in detail lines and hide the beams...
Thanks in advance!
Mon, Oct 25, 2010 at 2:47:26 PM | How can I radius my coping of steel beams?
gregroberson
gregroberson Avatar
Lonz,
This kind of stinks for a work around but should work: Model an "opening by face".  Still may take time, but looks good in 3D and such.
Greg
Mon, Oct 25, 2010 at 3:03:05 PM | How can I radius my coping of steel beams?
Lonzo
Thanks Greg. Actually I'm going into the extensions mgr and "freezing" them, exploding them, and then radiusing them... (sounds violent, I know!)...
Thanks again!
Lonzo
Mon, Oct 25, 2010 at 3:05:16 PM | How can I radius my coping of steel beams?
How about a simple masking region?  Only the curved line of the mask is solid and the other two hidden.
BTW... create one and copy many...
Mon, Oct 25, 2010 at 3:45:18 PM | How can I radius my coping of steel beams?
TKennedy
4 Stars: 8 Votes
WWHub's suggestion to use masking regions is how we did it when I was in a structural office. Seemed to be the least PITA method.
Mon, Oct 25, 2010 at 3:58:50 PM | How can I radius my coping of steel beams?
Lonzo
WWH & TK, thanks a bunch... I'll give it a try.
I'm working on some assembly drawings for a metal shop... lots o' fun!
Thanks again!Lonzo
Mon, Oct 25, 2010 at 4:06:03 PM | How can I radius my coping of steel beams?
gregroberson
gregroberson Avatar
Using the model opening by face option makes the geometry real in mutliple views (ie: 3D).  In addition, the projected lines of the material are shown, including the radius.  No faking all real gemoetry cuts.
Mon, Oct 25, 2010 at 5:02:18 PM | How can I radius my coping of steel beams?
TKennedy
4 Stars: 8 Votes
Using an opening does work, and I would use it on occasion where I would be looking at the same connection in multiple views, but I always ended up going back to masking regions for most of my details. I didn't really like it (I would rather model stuff correctly rather than "fake it in"Winking, but I just couldn't beat it for speed, especially when it came to copying and pasting the masking region (and other detail elements) into a dozen different details, and tweaking it to fit.
Lonzo, I would suggest trying all the different methods. They will all get the job done, but one might be easier than another for you.
Coping beams in a family
Tue, Mar 25, 2014 at 10:27:16 AM
Help with Steel I-Section Beams
Wed, Mar 3, 2004 at 7:13:07 AM
Steel Beams
Thu, Aug 4, 2005 at 8:46:03 AM
Aligning top of column to top of beams that are set out by bottom of steel
Thu, Dec 12, 2013 at 12:35:41 PM
connecting steel beams
Thu, Apr 8, 2010 at 9:33:24 AM
Page generation time: 0.7813
