Forums >> Revit Building >> Technical Support >> boulder retaining wall
Mon, Oct 24, 2005 at 4:50:41 AM | boulder retaining wall
BOOGIE007
Hi to all Does anyone who have or create boulder retaining wall or just large rock. I am using Revit 8.0 Thanks Jim
Mon, Oct 24, 2005 at 8:27:56 PM | RE: boulder retaining wall
eldados
eldados Avatar
4.5 Stars: 8 Votes
I had to do a boulder retaining wall once.. all I did was an in place family the full size of the retaining wall and hatch with a big rock pattern, cutting a section through I used detail lines to show shape of boulders... this is the fastest easiest way. you could, if you have time, import the boulders from the site components and build your wall stone by stone, this is fiddly and time consuming. you need to weight your options, not everything need to be modelled in 3D excactly to look good! Smile HTH
Integrator
KarelCAD
boulder retaining walls on a steep site
Wed, Sep 26, 2012 at 8:15:05 AM
Revit Architecture 09- Topography and Retaining Wall
Mon, Oct 12, 2009 at 4:15:33 PM
Creating curved retaining wall that aligns to topography...
Thu, Dec 22, 2011 at 12:30:03 PM
Retaining walls on site
Tue, Apr 15, 2008 at 6:02:54 AM
Buillding Road and Retaining Wall in Revit
Tue, Apr 30, 2013 at 7:28:21 AM
Page generation time: 0.8365
