5 Users Online (3 Members):
Forums >> Revit Building >> Technical Support >> Showing upper level with dashed line?
Hi, i could not able to show the projection of the upper level such as floor edges? I entered the view properties and there is underlay selection.Although i can select upper level here, it does not create dashed line. If anyone can show me the best way in REVIT 2011 , i will be grateful. Thanks Alper
I think you can do that in Visibility settings "VV"... overwrite the lines for that element.
"If you tell the truth, you don't have to remember anything" |
thanks for your answer, actually i found the same topic in the forum (http://www.revitcity.com/forums.php?action=viewthread&thread_id=7446  . someone previously asked the same question and there is also nice video explains the way. but as i understood there has not been yet easy way to show BIM element automatically with dashed lines. We have to define which lines will be overhang... so sorry about the extra topic... alper
Wall/Upper Cabinet |
Thu, Apr 22, 2010 at 1:02:31 PM
objects above - dashed line |
Fri, Oct 21, 2005 at 4:43:04 PM
Floor slabs showing dashed instead of Solid |
Wed, Jun 5, 2013 at 5:53:00 PM
12
Section through floor graphic shows dashed lines |
Wed, Oct 26, 2016 at 9:41:56 AM
how to see upper levels dash lines at the ground floor? |
Thu, Dec 24, 2009 at 2:26:32 AM
