16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Drafting View Catalog with View Names
36 Posts No Rating |
Revit Architecture 2009 We have over 1000 2D Drafting views that have been saved out from various projects to an rvt file. I want to print out all views and begin to organize them so that we have a detail library. The problem is, if I print all the views on 8.5x11 sheets, I have no way of knowing what the name of each view is. Is there a way to automatically label each view? The only thing I can think of is creating a giant sheet so that each view has a title, and window plotting 1000 times. Thanks!
Autodesk Revit MEP 2015 |
Why don't you place all these views in one file then place tose on sheets, label and print from there. Actually - don't kill another tree ! Once in the file, organized by category, with multiples placed on a sheets and titled, these views are easier to find, look at and import into a project. At least that is what we have discovered.
I found a 2 step workaround. But you need Bluebeam software, although this might work for Adobe Acrobat as well. I ended up plotting to pdf (we use bluebeam) and creating an individual pdf file for each view. Revit will then name each plot according to it's view name - if not on a sheet. Then, using Bluebeam PDF, I can batch plot these with a header or footer that shows the filename - which was the view name when it was in Revit. Thanks WWHub for your input.
1 Posts No Rating |
where you able to print the title on sheet attribute as well? how did you do that? i have revu extreme
referenced sections |
Wed, Apr 2, 2008 at 1:06:05 PM
Flagging new Drafting Views - How to reference a drafting view detail? |
Wed, Aug 1, 2007 at 10:26:29 AM
Trouble copying detail items from Section View to Drafting View |
Mon, Aug 19, 2013 at 1:08:05 PM
Using a callout on a drafting view |
Fri, May 16, 2008 at 10:39:58 AM
Problem with importing drafting views from file .... |
Fri, Oct 1, 2010 at 8:37:18 AM
