Forums >> Revit Building >> Technical Support >> Rendering image files
Fri, Oct 22, 2010 at 9:24:26 AM | Rendering image files
SteveB
3.5 Stars: 5 Votes
where can you select custom textures (from .jpg files) into the rend appearance dialog?  i cant find anywhere to drop them in in r2011
Fri, Oct 22, 2010 at 9:55:13 AM | Rendering image files
StClairMaverick
Its not very obvious where to select the new image files. When you're in the render appearance dialog with an existing material you want to change, click on the sample of the image and a new window will open. Then click on the image "source" link and a file browser will open to select a new image file.
hope that helps
Fri, Oct 22, 2010 at 11:51:43 AM | Rendering image files
SteveB
3.5 Stars: 5 Votes
thanks - i wouldn't have found that... couldnt find it in the docuementation either!
Looking for rendering image files for brick
Fri, Nov 6, 2009 at 10:01:41 AM
Image Files or Bitmaps
Fri, Apr 23, 2010 at 5:03:30 AM
When Rendering, background image get realy bad
Sat, Nov 11, 2006 at 11:54:44 AM
REA 2009 Background Image when rendering
Mon, Nov 17, 2008 at 8:50:49 AM
Capture Rendering/Export Image
Wed, Aug 15, 2007 at 10:34:26 AM
Page generation time: 0.4125
