Forums >> Revit Building >> Technical Support >> HELP ME PLEASE! WALLS DO NOT APPEAR
Fri, Oct 22, 2010 at 3:25:03 AM | HELP ME PLEASE! WALLS DO NOT APPEAR
mwtsilvia
4.5 Stars: 2 Votes
I just installed revit 2010 but unfortunatelly when I open an imperial template it shows me the walls in metrical system! I need the walls to be in inches Sad can someone please help me ASAP....Attached an image
Fri, Oct 22, 2010 at 4:44:06 AM | HELP ME PLEASE! WALLS DO NOT APPEAR
4 Stars: 205 Votes
Are you sure you are opening an "Imperial Template"? other thing, type UN in your keyboard and check the units.
Fri, Oct 22, 2010 at 1:04:50 PM | HELP ME PLEASE! WALLS DO NOT APPEAR
mwtsilvia
4.5 Stars: 2 Votes
Yes! I opened an imperial template and changed units and still the walls are in metric Sad
Fri, Oct 22, 2010 at 1:40:04 PM | HELP ME PLEASE! WALLS DO NOT APPEAR
4 Stars: 205 Votes
Go to the big "R" (like you can see in the first image) and select "new > Project" the browse and select the imperial template (second  image).
Fri, Oct 22, 2010 at 1:47:52 PM | HELP ME PLEASE! WALLS DO NOT APPEAR
mwtsilvia
4.5 Stars: 2 Votes
Dis it! the thing is I dont know why I had no imperial temlpates installed when I downloaded revit. I just download from the web page the nes  templates Smile
Fri, Oct 22, 2010 at 2:24:55 PM | HELP ME PLEASE! WALLS DO NOT APPEAR
4 Stars: 205 Votes
here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12827697
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:35 PM
Page generation time: 2.3533
