Forums >> Revit Building >> Technical Support >> structural members along dxf lines
Sun, Oct 23, 2005 at 11:29:07 PM | structural members along dxf lines
sydneysider
I was wondering if it possible to 'pick' lines from a dxf geometry to create a 3d geometry of individual structural members. This would be very useful for analysis --> rapid documentation
Mon, Oct 24, 2005 at 3:40:36 AM | RE: structural members along dxf lines
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You can trace the lines with structural framing set the appropriate profile to generate the framing. Picking is not possible as structural framing needs a start and end point in order to define the profile direction, if using the pick tool i'd imagine the structural framing wouldn't know which end your want to be which. Not much more work though. You also need to define the work plane first before drawing the structural framing. Best to use reference planes as they can be rotated as needed to change hosts should you need to. HTH.
Structural link showing colored lines - please help!
Thu, Dec 2, 2010 at 3:32:36 PM
Sloping Structural Members
Sun, Jan 9, 2005 at 5:32:40 PM
Curved structural members??
Tue, Apr 6, 2010 at 11:35:56 AM
Cutting Structural Framing Members with other members in Revit 2012
Tue, Jan 31, 2012 at 10:54:50 PM
Revit 2012 Truss System (framing members not showing)
Wed, May 9, 2012 at 9:25:33 AM
Page generation time: 2.4655
