Forums >> Revit Systems >> Technical Support >> HOW do I render my floor panelling to look like realistic woodgrain?
Fri, Oct 22, 2010 at 3:01:59 AM | HOW do I render my floor panelling to look like realistic woodgrain?
CRB14
I'm a newbie and have only a few more days to nail a render. In order to do this, I need to figure out how to render my floor with realistic wood panelling. The floor is a pattern made from individual tiles at the moment and currently just renders as Cherry Wood. To make the pattern stand out, I need to apply realistic woodgrain and varying colour tones. Please help!!
Thanks
Fri, Oct 22, 2010 at 4:18:29 AM | HOW do I render my floor panelling to look like realistic woodgrain?
4 Stars: 205 Votes
You can change the material to that floor like you want, just go Render Appearence and change the texture and the colour tone  like you want.
Fri, Oct 22, 2010 at 4:55:35 AM | HOW do I render my floor panelling to look like realistic woodgrain?
CRB14
Thanks for that - only thing is, I've done several renders using this method but the floor 'tiles' all render with a sort of fake texture. If I dowload an image of realistic woodgrain, is there a way I can use that instead? The problem is, the floor is made up of a series of pieces of wood which all radiate out from the centre of the room in a star shape. In order for this pattern to really come to life, I need to utilise a real texture I think instead of the ones that are already loaded into Revit. If you have any ideas re: this Id love to hear them! Thanks heaps for your help so far!!
Fri, Oct 22, 2010 at 5:25:31 AM | HOW do I render my floor panelling to look like realistic woodgrain?
4 Stars: 205 Votes
"If I dowload an image of realistic woodgrain, is there a way I can use that instead?" - YES
Go to materials, select a "Default" then duplicate, in render appearence you can change/apply a new image (jpeg) to the texture you want, then you can adjust the scale, rotation and so on...
Edited on: Fri, Oct 22, 2010 at 1:09:36 PM
Fri, Oct 22, 2010 at 11:51:09 AM | HOW do I render my floor panelling to look like realistic woodgrain?
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
Typhoon is right... you can also, add an "bump" map/image. that should give you what you want. Just play around with the settings and do some draft renderings.
 "If you tell the truth, you don't have to remember anything"
Sat, Oct 23, 2010 at 5:57:36 AM | HOW do I render my floor panelling to look like realistic woodgrain?
CRB14
Thanks heaps you guys- I've played around with the woodgrains offered in Revit and attached an image to show where I am at. The difficulty is, (see floor plan), there is a star like pattern on the floor that I want to bring to life, and my renders still don't show definition in the pattern.
I somehow need to darken or define the 'grouting' or space between wooden planks......any ideas of howto do this? I feel like I'm drowning in the deep end here! Thanks so much so far..
Sat, Oct 23, 2010 at 6:08:10 AM | HOW do I render my floor panelling to look like realistic woodgrain?
4 Stars: 205 Votes
Your images are too small, i can't see the problem but to define the 'grouting' or space between wooden planks you can create a sweep or a reveal in that floor, that sweep can have a dark color so when you render you will see the effect you want.
Edited on: Sat, Oct 23, 2010 at 6:08:55 AM
WOODGRAIN RENDER - WHAT'S WRONG WITH MY RENDERING? PICS ATTACHED
Tue, Nov 9, 2010 at 11:52:32 AM
What is the best way to build this complicated FLOOR PATTERN???
Tue, Mar 15, 2011 at 6:55:20 PM
Timber panelling 3'-0" high within room Revit 2010
Thu, Nov 19, 2009 at 1:55:35 PM
realistic materials
Mon, Jul 6, 2015 at 9:03:32 AM
Having problem with realistic style mode in Revit Architecture 2012
Wed, Jun 22, 2011 at 8:04:36 AM
Page generation time: 3.1676
