Forums >> Revit Building >> Technical Support >> Sweep in Various Plans
Wed, Oct 20, 2010 at 12:25:39 AM | Sweep in Various Plans
LSY2010
Can anyone help me with creating a sweep that travels along the Z-Axis , then X-Axis, then the Y Axis and back to the  Axis.  I have tried setting work planes but Revit wont aollow me to creat them on the diffrent axis to draw my path.  My goal is to show duct work as it moves through the building.  Whats the best way to accomplishthis.
thanks
Wed, Oct 20, 2010 at 5:33:16 AM | Sweep in Various Plans
4 Stars: 205 Votes
Look, use "Model Lines" to create the "Skeleton" of the path/object then use "Solid Sweep" and use "Pick Path".... just like that...
Watch this: http://www.revitcity.com/forums.php?action=viewthread&thread_id=19342&start=15
Wed, Oct 20, 2010 at 8:59:01 AM | Sweep in Various Plans
LSY2010
Thanks for the reply, but I'm still have the problems of getting my path to connect when I transition to a travel in the Z direction.  Im I supposed to be adjusting the work planes or something?
Wed, Oct 20, 2010 at 12:30:30 PM | Sweep in Various Plans
4 Stars: 205 Votes
I'm working in Revit Arch. not in MEP but you must "play" with the "Work planes" and differents views to create that kind of skeleton.
Wed, Oct 20, 2010 at 12:38:04 PM | Sweep in Various Plans
LSY2010
I forgot to mention I'm using Revit 2011 as well.  I'm just using the sweep command to represent the duct work.  How can I change the planes to accomplish a model similar to what you did in the phto u sent earlier?
Wed, Oct 20, 2010 at 1:00:20 PM | Sweep in Various Plans
4 Stars: 205 Votes
Watch the video: http://screencast.com/t/JmgvaXtzUuiP
Wed, Oct 20, 2010 at 1:20:46 PM | Sweep in Various Plans
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
If I understood you correctly..... sweep works only on one plane at a time... (i.e., X,Y or Z,X...) you cannot join continous path in different directions to form solid sweep. But you can "intersect" them.
 "If you tell the truth, you don't have to remember anything"
Wed, Oct 20, 2010 at 5:46:30 PM | Sweep in Various Plans
LSY2010
WORKED PERFECTLY!!!  Thanks!  I have my life back!
Thu, Oct 21, 2010 at 9:23:30 AM | Sweep in Various Plans
GRINHEART
GRINHEART Avatar
4 Stars: 5 Votes
I didn't know that would work... very nice Typhoon!
Wall sweep shows where it should not
Mon, Apr 16, 2007 at 4:59:52 PM
site plans and buildings plans
Tue, Apr 17, 2012 at 8:40:07 AM
Can You Flex a Sweep in Components
Mon, Jun 3, 2013 at 2:09:23 PM
Sweep Profiles in Version 9
Thu, Aug 3, 2006 at 2:14:05 AM
Using Area Plans as Main Floor and Unit Layout plans
Mon, Mar 29, 2021 at 1:59:33 PM
Page generation time: 0.7600
