29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Structural Column Appears as line
Using the structural columns from the imperial library (i'm using 2010), the column appears in elevation as a single line, rather than a 3D object. The family extrusion's visibility settings are set so that it is supposed to show in all views, but it just shows up as a representational line. what am i missing?
Check your detail level.
that was it! thank you.
0 Posts No Rating |
Thank you
0 Posts No Rating |
Thanks!
Visibility graphics of a structural column |
Mon, Aug 16, 2010 at 8:21:00 AM
Created channel column shows off its structural axis (physical appart blue line) |
Thu, Jun 27, 2013 at 5:46:12 AM
Structural Column not working |
Mon, Jul 2, 2018 at 10:20:09 AM
structural column visability |
Thu, Sep 8, 2011 at 1:14:26 PM
structural column member not selectable |
Wed, Jul 19, 2006 at 9:26:06 AM
