Forums >> Revit Building >> Technical Support >> Door room boundary
Tue, Oct 19, 2010 at 11:43:47 AM | Door room boundary
ccristiana
Can someone explain me how can i define a reference plan to room bounding inside a door family? Or defining the door panel as room bounding?
This is, when I place a door it is aligned with one of the wall faces. The room bounding is made with the wall center. When applying room legend with different fills, it results strange, it doesn´t respect the door face, the fill extend to the wall center...
Any way to escape this centered fill division?
Thu, May 24, 2012 at 4:31:46 AM | Door room boundary
kikusko
Where can i find answer to this question?
Thu, May 24, 2012 at 7:24:50 AM | Door room boundary
Sorry but I don't see a way to do this.  You will have to turn off room bounding for the door and add it manually if it is really a problem.
Structural column doesn't define room boundary (but only sometimes!)
Wed, Apr 1, 2015 at 10:23:56 AM
Room Boundary Issue [ 1 2 ]
Tue, Sep 11, 2012 at 12:46:42 PM
21
Room boundary issue
Sat, Sep 21, 2019 at 8:21:34 AM
Reshaping Room Boundary
Tue, Mar 11, 2014 at 3:34:24 PM
delete room space / boundary
Sat, Feb 16, 2013 at 1:30:02 AM
Page generation time: 0.5223
