31 Users Online (29 Members):
Forums >> Revit Building >> Technical Support >> Beginner Question with Scale on Viewport
1 Posts No Rating |
Very new to Revit, so I need some help. When I place a drafting view on a sheet, it displays a title (which I want) but it also displays a scale (which I do not want) I just want it to say "vicinity map" but have no scale. I have duplicated the "viewport 1" and tried to change the properties, but can not find where to take off the scale. Thanks in advance.
You need to edit (or make a new family) the View Title family. You can edit the existing family so you can turn the scale label on and off with a parameter, or if you don't want to do that you can delete the scale label, save as a new family, then load the new family into the project. Once that is done you can go back into the viewport properties and tell it which family/type to use.
watch this video. it is on a different subject, but it does what you want to do. http://www.screencast.com/users/NMcClure/folders/Revit%202010%20Tutorials/media/8382a723-25b3-4086-b199-3f52648da7ef
REVIT Building 9.1: viewport and scale on dwg sheet |
Tue, Apr 17, 2007 at 4:34:27 PM
Metric Viewport in an Imperial Unist based project |
Mon, Aug 11, 2008 at 9:16:58 AM
downsizing a viewport |
Thu, Jul 8, 2010 at 7:03:43 AM
viewport title with line question |
Tue, Jul 8, 2008 at 11:38:17 PM
Viewport larger then needed on sheet |
Tue, Feb 20, 2007 at 10:38:25 AM
