Forums >> Revit Building >> Technical Support >> Moment Frame Symbols
Mon, Oct 18, 2010 at 4:24:51 PM | Moment Frame Symbols
zoommby
I am running Revit 2011 Architecture.  I do structural drawings as well as architecture.  I would like to indicate moment frames in my drawings with the typical solid filled triangle at the ends of the beams.. I have gone into element properties of the beams and set the ends of the beam to moment frame.  In the comments field I have placed the text Moment Frame.  I have loaded the Annotation symbol family Connection-Moment-Filled.rfa.  No symbols appear in my drawing.  My detail level is set to course.
 There is also talk in the Mastering Revit Structure 2009 manual of a Structural Settings Dialog box.  Is this dialog available in Architecture.  I can't find it in my menus if it is.
Thanks
Fri, Apr 8, 2011 at 8:43:43 AM | Moment Frame Symbols
renal74
did you get an answer to your problem?  i am having the same one.  my project used to show the moment frame but now they have disappeared.
thanks
Moment Frame symbol is grey
Fri, Jul 28, 2017 at 7:51:13 AM
window frame family + nested window frame fill
Wed, Apr 12, 2006 at 7:31:30 AM
MISSING MOMENT FILLED CONNECTION
Wed, Apr 4, 2012 at 9:34:26 AM
Deleting import symbols
Thu, May 8, 2008 at 3:14:21 PM
Warehouse Structure
Thu, Feb 3, 2011 at 11:19:22 AM
Page generation time: 2.5009
