Forums >> Revit Building >> Technical Support >> Revit 101 questions...(pertaining to UCS)
Sat, Oct 22, 2005 at 3:28:07 PM | Revit 101 questions...(pertaining to UCS)
CDone
Forgive me if I use the ADT terminology, but I am new to this.....I am trying to recreate a set of drawings of a house that my office did in ADT as a starting point. I have the first floor walls up. This is CMU and concrete construction BTW. My top of tie beam is at 11'-8" AFF and it is a 12" tie beam. I have the top of CMU walls at 10'-8" and I was going to create a 12" tie beam (thus 11'-8" T.O.T.B.). My first quesiton is, can I create a cmu wall with a tie beam built into it, or do I have to do it from 2 pieces (tie beam sits on top of cmu wall)??? Now I'm doing it as 2 separate piece right now but I cannot get the tie beam to sit on top of the cmu wall. I cannot get my working plane to be at 10'-8" AFF so I can just draw in my tie beam in plan view. I feel like I have to give it some type of UCS command to get my working plane to the elevation it needs to be at and then make my UCS a "world" view (as in ADT). Please help.
Sat, Oct 22, 2005 at 4:37:19 PM | RE: Revit 101 questions...(pertaining to UCS)
Scott Davis
3.5 Stars: 3 Votes
create a new level at 10'-8",call it Tie Beam or whatever you'd like. go to the plan view for the new level and draw your beam.
Sat, Oct 22, 2005 at 5:20:46 PM | RE: Revit 101 questions...(pertaining to UCS)
Rythmick
5 Stars: 2 Votes
You can set T.O.W at 11'-8" when you place your beam from T.O.W. plan view it will place the T.O.B. at T.O.W., You can adjust the level of the beam if needed by selecting the beam going to its properties and adjust it's elevation parameter. The wall will not prevent the beam from being placed. If you want to show and or cut a beam pocket into the wall you will need to use "Create' to make a void and use that void to cut the pocket into the wall.
UCS?
Sat, Oct 7, 2006 at 3:54:16 AM
Shocking Survey Data, nothing drawn to a UCS! slightly off axis errors imenent!!
Mon, Dec 10, 2012 at 10:30:08 AM
Please state Revit version being used in your questions [ 1 2 ]
Thu, Dec 15, 2016 at 6:32:17 AM
22
Space "number" parameter to Multi-Category Tag?
Fri, Dec 13, 2013 at 10:13:13 AM
noob with questions and some experience
Sun, Oct 4, 2009 at 5:21:38 AM
Page generation time: 1.3896
