Forums >> Revit Building >> Technical Support >> how to make beams from a mass model, and how to add a floor to it
Sat, Oct 16, 2010 at 4:50:37 PM | how to make beams from a mass model, and how to add a floor to it
danielacm
here is attached  the start of the first floor of my project, this first floor is half suspended, that´s why it has a beam on the low part....
1-I want to know how to convert this lower and upper beams made of  conceptual mass  in "real" beams (that revit can recognize them as structural components, assingn a meterial etc..)once I've exported it to a revit project.
I really need to now if I can do this in order to decide if it worths to continue or not..
other doubt :
2-is that I need to asign a glass floor to on it, this conceptual model is nly the structural part... how can I put right on this structural floor that "epidermis" ?
Sun, Oct 17, 2010 at 7:20:06 AM | how to make beams from a mass model, and how to add a floor to it
4 Stars: 205 Votes
1.  You can assign "Material" to those elements BUT you can't convert that to other category, in this case structural, like you can see in my image. I don't think this is a good idea to create this kind of beams in a "Mass" family.
2.  Just create a floor with the thickness you want and change the material to Glass.
Sun, Oct 17, 2010 at 9:08:58 AM | how to make beams from a mass model, and how to add a floor to it
danielacm
If you don´t think is a good idea to create that kind of beams in a mass family what would you suggest?, what's to way to make an "organic" structure?
Sun, Oct 22, 2017 at 1:10:11 PM | Typhoon
bparker02
Quoting Typhoon from 2010-10-17 07:20:06
I know this post is really old but I've been having a really hard time as a new Revit user creating certain items. I've probably spent 3 hours trying to learn how to mass a special roof joist / rafter / beam (get these terms in for seach purposes). The problem was I could easily build the model but it would get locked to the plane I built the rafter on and I couldn't array it down the ridge of the roof. Simple fix, make it a wall!!! Viola!!
THANKS!!
add beams conceptual mass
Tue, Oct 15, 2013 at 7:52:39 AM
Floor Joists
Tue, Apr 1, 2008 at 1:53:41 PM
Issue creating mass floor area schedule (mix of families & 'model in place' mass
Thu, Sep 27, 2012 at 7:05:36 AM
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:03 AM
RVT2015 - Insert steel beams over doorway
Tue, Apr 25, 2017 at 9:06:47 PM
Page generation time: 3.4721
