Forums >> Revit Systems >> Technical Support >> adding control points on a mass model
Fri, Oct 15, 2010 at 11:08:17 PM | adding control points on a mass model
danielacm
I´m starting this model and I I have a problem... look at the joint betwwen the "beams" in the level one and level 2....I can´n join them because there are no control points in the upper beam (mass), I did this upper beam with a solid sweep, can you helpe to figure out how to add or visualize it´s control points to move it and clean the joint?
thanks!
Mass Geometry Flaw | Circle points
Fri, Dec 4, 2015 at 4:04:46 PM
Adding elevation points to accessible ramp with curves
Fri, Apr 17, 2015 at 10:54:07 AM
Floor/slab boundary
Wed, Aug 26, 2015 at 2:14:50 PM
Beam control points
Mon, Jun 29, 2009 at 10:15:25 AM
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:03 AM
Page generation time: 0.7504
