Forums >> Revit Systems >> Technical Support >> Unable to select ductword! (on 1st floor only)
Fri, Oct 15, 2010 at 4:46:52 PM | Unable to select ductword! (on 1st floor only)
nickh
I am using Revit MEP 2011. Everything has been going reasonably smooth until today, when I opened up my model, and on the First Floor am only able to select objects by WINDOWING and not by simply clicking on the object. The only exception to this being any annotation or section lines.
Second Floor and penthouse level works fine, and I cannot figure it out. I did a search on here and found a few people with similar issues, but no solution.
HELP!
Thanks
Fri, Oct 15, 2010 at 5:15:41 PM | Unable to select ductword! (on 1st floor only)
nickh
Nevermind, I just figured it out!
Somehow my view template had been changed from "Mechanical Plan" to "Architectural Elevation". Hence not being able to select mechanical objects without Windowing.
1st floor to 2nd floor
Sat, Apr 7, 2012 at 10:01:20 AM
Unable to select grid lines after pinning them
Fri, Dec 13, 2013 at 5:42:49 AM
how to see through floor cut opening on plans?
Thu, Nov 18, 2010 at 10:02:14 PM
Unable to select the fill region
Mon, Aug 13, 2012 at 3:51:58 PM
I SEE 1ST FLOOR FROM 2ND FLOOR PLAN...WHY IS THAT?
Tue, May 29, 2007 at 1:33:49 PM
Page generation time: 2.1949
