Forums >> Revit Systems >> Technical Support >> Rotating Families Vertically
Fri, Oct 15, 2010 at 10:12:59 AM | Rotating Families Vertically
RevitFTW
I have been festering with this for a few hours now, looking at a dozen threads and I can't get anything to work.  I'd like to rotate a family in a left or right view when I nest it into another family I'm creating to build a radiant heat manifold.  I've use the Generic Model.rft template for all my manifold accessories.  CAN ANYONE PLEASE HELP!!   I've attached one of the files...
Fri, Oct 15, 2010 at 10:37:21 AM | Rotating Families Vertically
TKennedy
4 Stars: 8 Votes
In Family Categories try turning off Always Vertical and turning on Work Plane Based. Then pick a new plane for it. You can use faces of other geometry as work planes. It seems like it wants a horizontal WP initially (won't let you pick anything else), but once it's on a new WP you can rotate it.
Fri, Oct 15, 2010 at 11:03:10 AM | Rotating Families Vertically
RevitFTW
That seems to be working!  I thank you a thousand time over!
Also, anyone know why blends and revolves look like crap when trying to make a circular object?  They all end up looking like octagons, even in the rendered model...
Rotating Schedules?
Tue, Feb 19, 2008 at 11:51:23 PM
Rotating Symbol geometry without rotating leabel
Wed, May 6, 2009 at 8:33:58 AM
Rotating Family Text
Wed, May 7, 2014 at 5:04:06 PM
rotating in Y axis?
Wed, Feb 13, 2013 at 3:30:01 PM
Revit MEP 2009 - Vertically stacked devices (families) overlapping
Sat, Jun 20, 2009 at 3:40:21 AM
Page generation time: 5.7488
