Forums >> Revit Building >> Technical Support >> MOVE GRID LABELS ON ONLY ONE DRAWING
Fri, Oct 15, 2010 at 4:48:19 AM | MOVE GRID LABELS ON ONLY ONE DRAWING
Daveybdab
Hello, appologies if this has been asked before but i couldn;t find an answere in theforum. I have a grid that i am using on all my G.A.s. when i move the grid labels (the circle with the number or letter in) on one G,A. the change is repeated on all the others. (note that i am only moving the grid labels parallel to the grid lines, not actually moving the grid lines.). Anyway I have a drainage drawing with move info on it, on this drawing i want to show the grid labels further out so they don;t clash with the sewers ont he drawing. The problem is that if i do this it also moves the grid labels on the other drawings which i do not want it to do.
How can i have the grid labels at different positions on different drawings?
thanks for any help
Fri, Oct 15, 2010 at 7:37:51 AM | MOVE GRID LABELS ON ONLY ONE DRAWING
When you click on a grid, you will see a perpindicular temporary line that marks the end of the grid.  On that line you will see a lock and either 3D or 2D.
In your case, you are seeing 3D which means if you move the grid end, it moves in all views.  Click on the 3D and it will change to 2D.  Now when you move that grid in that view, it is only in that view.
Sat, Jul 12, 2014 at 1:56:41 PM | MOVE GRID LABELS ON ONLY ONE DRAWING
aaurnab
aaurnab Avatar
2.5 Stars: 3 Votes
Thanks a lot
Grid Labels not visible while drawing a grid
Mon, Oct 15, 2012 at 3:29:21 PM
Help on Grid Label
Fri, Nov 8, 2013 at 4:38:40 AM
Ceiling grid modification Not happening help
Sun, Jan 8, 2012 at 8:19:11 AM
Custom Grid Heads
Tue, Apr 26, 2011 at 6:43:55 AM
grid lines question revit 2009
Tue, Nov 25, 2008 at 12:03:27 PM
Page generation time: 0.5677
