10 Users Online (8 Members):
Forums >> General Discussion >> Revit Project Management >> Complex Healthcare Projects - Can Revit do their equipment schedules too?
Hi All, I just started work with a new firm using ADT ( AutoDesk Architecture ) primarily within large Healthcare Projects. They are considering moving to Revit but are worried about losing their extensive library of healthcare equipment. Having used Revit now for 5 years, I am keen to make the move as its so much easier. The questions I need peoples comments are: Can Revit handle complex healthcare projects? Can Revit cater for the production of complex equipment schedules that are found in such large projects? Many Thanks in Advance Beau
There are many many people using Revit for health care. Of which I've been involved with a couple. A few have used Codebook in conjunction with Revit for the Room Data Sheets. However, provided you have the library setup with the appropriate parameters the generation of the equipment schedules is quite easy. So yes Revit can definitely handle complex healthcare projects. Yes Revit can create complex equipment schedules and room data sheets, provided you invest the time generating the library of components.
Regards,
Chris.
i just have t ditto Mr.Spot. Revit can do whatever you need, but you must provide it with want it needs to do what you ask.
Edited on: Fri, Oct 15, 2010 at 9:12:52 AM
43 Posts No Rating |
mr spot would i be able to pick your brains re room data sheets?? need a bit of advise re: development of revit and ADB
Have you ever thought about using a schedule key for this? It works fantastic!
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here |
Boo on Codebook....what a waste of time.
Equipment Schedules |
Tue, Jun 17, 2008 at 11:39:12 AM
Schedules and areas |
Tue, Jan 19, 2010 at 1:40:28 PM
Complex roofs for high end residential projects |
Wed, Oct 10, 2018 at 2:10:11 PM
Automate Room Equipment Schedules. |
Fri, Mar 22, 2019 at 4:24:12 AM
Schedules arrrrgggghhhhhh!!! |
Tue, Jun 22, 2010 at 10:49:04 AM
