Forums >> Revit Systems >> Technical Support >> Instance Based Parametric Array
Thu, Oct 14, 2010 at 4:30:47 PM | Instance Based Parametric Array
wsquiers
This is a continuation of a previous thread I created some time ago. I am trying to create a parametric louver family where I can insert the louver and manipulate its size via grips (and have the blades change length and number depending on the louver size) rather than by creating different family types for each louver size.  I have created a line based louver blade (with various parameters such as width, thickness and angle) and inserted it into a line based louver and array the blades, but I receive an error message saying I can't have an instance parameter in a type parameter when I write an formula for the blade spacing.  Is it even possible to create a instance based louver family that can be changed by draging grip?
Thu, Oct 14, 2010 at 10:41:30 PM | Instance Based Parametric Array
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Yes its possible.  You just can't drive a type parameter based on instance parameters.  You can drive an instance parameter based on Type parameters, or instance to instance.
As such, change your type parameter to instance.
Regards,
Chris.
Parametric array-Crop length of last instance to fit length
Fri, Feb 21, 2014 at 9:02:26 AM
Parametric Arrays
Fri, Feb 5, 2010 at 3:19:22 AM
Array on a Parametric Face
Tue, Mar 7, 2017 at 5:09:10 PM
Editable nested family inside parametric array host family
Wed, May 19, 2021 at 8:05:22 AM
Centering a parametric array in a family - RAC 2009
Thu, Jul 16, 2009 at 12:10:04 PM
Page generation time: 0.8643
