Forums >> Revit Structure >> Technical Support >> Level Split
Thu, Oct 14, 2010 at 12:05:10 PM | Level Split
gregroberson
gregroberson Avatar
Does anyone know if you are able to "split" level lines in elevation views?  Similarly to the way you can split a section view so that the lables end up on the ends of my elevation but not through my entire picture?
Thanks in advance,
Greg
Tue, Apr 26, 2011 at 6:52:19 PM | Level Split
carlos72
I have the same problem. I don't want to show the level lines thru the entire elevation but rather to gap the center part and just show the both ends.
Just like you would gap the section lines.
it would be nice if this feature is available
Tue, Apr 26, 2011 at 6:58:16 PM | Level Split
thetabest
thetabest Avatar
3 Stars: 2 Votes
Negatory, I was going to suggest the lineworking tool, but it wouldn't work with the levels, so your best workaround is to use 2D extents on your levels, to the point where you want it to gap, and then use a linetype (make one under linetypes to be the same as a grid line) to draw a detail line where you want it to resume... THEN align that line to the level and lock it.  Next best thing...
GL
Trent Best
Best Systems
the.tabest@gmail.com
Tue, Apr 26, 2011 at 7:35:56 PM | Level Split
carlos72
Thanks your answering so fast.
Wed, Feb 1, 2012 at 4:02:28 PM | Level Split
Jandrade75
Here's a step-by-step to my work around.
1. Adjust the level that you need to split so that it shows correctly on one side of your view.
2. Duplicate the view and adjust visibility so that the level shows correctly on the opposite side of the view and adjust the Crop Region so that it only shows a small portion of the model. (this will be made quicker if you're using view templates)
3. Place that view over the existing view on the sheet (Revit will auto-align the views so you shouldn't see any overlap).
I name the second view the same as the first and add a number or letter after to keep them together in my browser (BUILDING SECTION C and BUILDING SECTION Ca. Hopefully, Autodesk will change this in the near future... See Attached PDF's for visual explanation.
Wed, Feb 1, 2012 at 4:04:31 PM | Level Split
That's a nice out of the box solution.  Thanks for posting.
split level homes
Tue, Feb 17, 2004 at 7:04:24 AM
Creating A Split Level Home *Need Help*
Tue, Sep 13, 2005 at 12:33:48 PM
View Range or Cut Plane Settings for Split level and Cape style
Fri, Jul 6, 2012 at 8:19:54 AM
How do you treat split levels or minor level changes?
Mon, Jun 26, 2006 at 10:40:01 PM
Windows not showing in split level floors -?
Thu, Jul 24, 2008 at 11:22:12 AM
Page generation time: 3.6458
