Forums >> Revit Building >> Technical Support >> Changing wall/wall tag parameter
Thu, Oct 14, 2010 at 11:52:36 AM | Changing wall/wall tag parameter
Dianthier
Dianthier Avatar
2.5 Stars: 3 Votes
I'm using Revit 2011.
When we tag a wall instead of the information from the tag going into the instance parameter of MARK for the wall, as it did in 2010, it's going into the type parameter of TYPE MARK so that we would actually have to create different walls for each different partition type.
Is there a way to change this connection??
Thanks - Diane
It's got to be happy hour somewhere
Thu, Oct 14, 2010 at 12:44:42 PM | Changing wall/wall tag parameter
You can create tags to read any parameter as long as it is a shared parameter.  Just edit the tag, give it a different name and poit that field to the other mark.
Creating a wall tag with a volume parameter
Sun, Jun 23, 2013 at 3:56:03 PM
Wall Tag Parameter
Fri, Mar 7, 2008 at 6:10:37 AM
Wall tag parameters
Wed, Mar 12, 2008 at 5:05:59 PM
Wall width tag
Wed, Mar 20, 2013 at 12:32:47 AM
Shear Wall Length
Tue, May 24, 2011 at 5:00:45 PM
Page generation time: 7.2331
