Forums >> Revit Building >> Technical Support >> Purging CAD files
Thu, Oct 14, 2010 at 11:46:48 AM | Purging CAD files
DAVID55555
So how do you purge CAD files that havent been linked (only imported)? I've gone thru every single detail in the whole set and there are no remnants of dwg's anywhere. But i see them when i go to Object Styles/ Imported Objects. They dont list when i try purge either. Anyone have this problem? Please help. Its driving me crazy
thanks,
D
Thu, Oct 14, 2010 at 12:03:32 PM | Purging CAD files
alabaster2513
alabaster2513 Avatar
3.5 Stars: 25 Votes
Just select those layers from object styles and delete them, you can also delete the "Render Material 255-255-0) and so on, those are materials associated with layers
Thu, Oct 14, 2010 at 12:20:24 PM | Purging CAD files
DAVID55555
Right but that only deletes the layers not the *.dwg files in the list. I did this and then renamed them JUNK but i thought there was maybe some other way. thanks,
Thu, Oct 14, 2010 at 12:54:55 PM | Purging CAD files
alabaster2513
3.5 Stars: 25 Votes
I think you are just seeing residual object data, the dwg is not physically in the project it just left the layer definitions behind.
Thu, Oct 14, 2010 at 1:15:41 PM | Purging CAD files
The CAD file is still in your project.  There is a app that will find these but I think it costs something.  These are very hard to find.  They could be hidden in view somewhere , in a detail or model family.
Read this thread:  http://www.revitcity.com/forums.php?action=viewthread&thread_id=18933
Thu, Oct 14, 2010 at 1:54:47 PM | Purging CAD files
DAVID55555
Thanks! I downloaded the add-on. Unfortunately,there hasn't been an update to the tool for Revit 2011 but i tried it on an archived template file and it totally worked and deleted all the extraneous dwg info. Thanks for the help. I'll have to wait for the update.
 Cheers!!!
Fri, May 19, 2017 at 12:06:54 AM | Purging CAD files
k065167
David, sorry for digging this up but did you manage to get an update to that app? The link in that post now points to a technology blog...
For the meantime, my colleagues gave me DWG Explorer which works great for removing imported cad files directly from VG. It also lets me quickly & visually locate individual dwgs in their views to make sure I won't upset anyone by deleting it.
I'm still on the lookout for even better solutions though...
Importing (civil) CAD in Revit
Mon, Jul 9, 2012 at 7:12:30 PM
Linked CAD files are not turning off
Tue, Nov 29, 2016 at 3:31:28 PM
14
Importing Cad Files
Tue, Mar 31, 2009 at 8:36:59 AM
Errors with hatches in imported cad files
Wed, Mar 14, 2007 at 3:16:31 PM
Export from Revit To CAD with RELATIVE linked files
Wed, Nov 29, 2017 at 11:00:35 AM
Page generation time: 0.8477
