Forums >> Revit Building >> Technical Support >> Phaseing Levels
Wed, Oct 13, 2010 at 10:24:00 PM | Phaseing Levels
EssG
Hi,
 Revit Arch 2009
I'm busy with a  Reno Project, where the existing house is going to be raised to build in underneath,,,,,I have Existing Site, Floor plan and elevations....Now I need to create proposed plans.....the problem is that when I change the levels for the reno showing the new levels  my existing elevations levels also move....Is there any way to move existing structure on  to new levels phased as proposed while keeping the same structure showing on the existing  elevations as the levels it was?
Cheers
Ess
Thu, Oct 14, 2010 at 5:07:21 PM | Phaseing Levels
EssG
Anyone?
Thu, Oct 14, 2010 at 10:38:08 PM | Phaseing Levels
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The best way I've found to do this is by having 2 files.
Link your existing building into a site file.  Demolish the existing building and then place another instance as new construction at the relocated height.
HTH.
Regards,
Chris.
Fri, Oct 15, 2010 at 6:23:50 AM | Phaseing Levels
EssG
Thanks Chris...I will give that a try Smile
Cheers
Phaseing`
Thu, Jun 28, 2007 at 10:54:04 AM
PHASEING HATCH LINES?
Thu, Jan 11, 2007 at 4:43:26 AM
Replacing levels with ref planes or deleting excess levels
Thu, Apr 17, 2008 at 11:10:37 AM
Levels missing Revit 2012 [ 1 2 ]
Mon, Sep 28, 2015 at 3:29:41 PM
19
Levels, Disappeared. [ 1 2 ]
Sun, Sep 24, 2017 at 7:44:33 AM
16
Page generation time: 2.2222
