Forums >> Revit Building >> Tips & Tricks >> Footing longer than the wall
Fri, Oct 21, 2005 at 2:05:09 PM | Footing longer than the wall
MalyAniolek
Hi all, I'm trying to make the continuous footing longer than the wall above it, but i simply can't find how to do it. on the pict, the red line is where the continuous footing stop, and i'd like to make it go further., does anyone know how to this ? Thanks
Fri, Oct 21, 2005 at 4:46:31 PM | RE: Footing longer than the wall
Rythmick
5 Stars: 2 Votes
The footing tool is fairly new and not fully developed yet, it's quite limited. Just make your footings using the wall tool or make a footing sweep family. In your case you can leave the continuous footings around the closed perimeter and remove the footing on the open ended wall and replace with one of the methods above.
Thu, Oct 27, 2005 at 2:48:42 AM | RE: Footing longer than the wall
MalyAniolek
Thanks Rythmick Smile
Continuous Wall Footing ?
Thu, Aug 23, 2012 at 1:59:47 PM
13
Problem when applying a footing to wall
Thu, Aug 23, 2012 at 1:58:50 PM
lower interior footing to match foundation wall footing
Tue, Mar 5, 2019 at 3:06:52 PM
Wall profile footing issure
Fri, Oct 3, 2014 at 7:06:49 AM
Double footing problem - plz help??
Thu, Nov 15, 2012 at 3:24:50 PM
Page generation time: 2.4464
