29 Users Online (27 Members):
Forums >> Revit Building >> Technical Support >> Wall graphics change with fire extiguisher box added
5 Posts No Rating |
I've used a couple of wall hosted recessed elements that give me problems sometimes in certain walls. For some reason it shows the wall as if it has a CMU layer which is not the case. I attached a before and after picture without the element. I'm using Revit 2011 but was also having the same problem in 2010. I'm sure its something in the recessed family but don't know what. I've attached that as well. Thanks in advance.
Try going to the wall properties and turning off "wraps at inserts." That might fix your problem. The crosshatch that dominates your "after" wall is the same hatch as your outermost layer on the "before." Kinda suspicious, there.
5 Posts No Rating |
It looks like that worked. Thanks!
Fire-tags |
Thu, Apr 6, 2006 at 2:21:21 AM
instance parameter on wall, fire rating |
Wed, Aug 7, 2013 at 11:49:49 PM
Revit phasing, wall and fire rating patterns |
Tue, Oct 17, 2017 at 7:03:03 AM
Wall Types and Fire Ratings |
Wed, Nov 30, 2011 at 12:59:50 PM
wall tapes/fire tapes |
Tue, Aug 25, 2009 at 7:55:44 AM
