15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Why doesn’t publish co-ordinates publish heights?
Hi, I’ve created a site model and linked in several buildings to for a campus project I am producing. I acquired the co-ordinates from a survey and published them to the linked buildings. All appears to have worked OK, the buildings now have the proper site location and have a Project North and True North orientation. But when I check the height levels in elevation they still show the levels from 0.000 and no the correct height I placed them at in the Site Model. Why didn’t the heights get published?? Cheers.
Once you have a site file lined up on the X,Y,Z axis and acquired the coordinates, you need to tell the level datums to read the shared coordinates. You do this by changing the type property "ELEVATION BASE" to shared rather than project.
Great - Thanks for that. But what happens if there is more than one instance of that building in the site model? i.e. it has several positions recorded - The elevation base box only gives you shared or project - How do you specify which one to display? Thanks.
Publish to google earth issue |
Sat, Feb 9, 2013 at 11:00:01 PM
Linked models, true north and publishing co-ordinates |
Thu, Oct 21, 2010 at 11:20:53 AM
publish to Buzzsaw |
Thu, Dec 14, 2006 at 5:29:10 AM
Publish to Dwf problem. |
Sun, Apr 18, 2010 at 5:28:53 PM
Cannot publish from a model with multiple named sites... |
Wed, Jul 15, 2015 at 9:17:19 AM
