Forums >> Revit Building >> Technical Support >> Best way to handle finishes for schedule and render
Wed, Oct 13, 2010 at 8:17:37 AM | Best way to handle finishes for schedule and render
archie456
3 Stars: 1 Votes
Hi,
What’s the best way to schedule finishes and also have them to produce nice renders.
My building uses concrete walls, which look great when painted, but not so good when just plain concrete.
If I add the finishes to the room object they are just text fields that bear no relation to the model.
If I add the finishes to the wall objects I end up with a load of wall types (too many).
If I add the finishes using the Paint tool it doesn’t schedule and I have to split up all the wall faces which takes too long.
How do others out there do this?
Cheers.
Finishes schedule with materials spec in it
Tue, Jun 5, 2012 at 1:42:43 PM
Schedule is Empty?
Wed, Feb 19, 2014 at 3:13:23 PM
scheduling door finishes and materials
Thu, Aug 13, 2015 at 2:54:53 PM
Creating a wall finishes schedule, and coding wall finishes on elevations
Fri, Jun 1, 2012 at 4:06:32 PM
Document Will Not Render
Fri, Aug 27, 2010 at 3:57:28 PM
Page generation time: 0.5390
