Forums >> Revit Building >> Technical Support >> Open doors in 3D view
Fri, Oct 21, 2005 at 4:47:56 AM | Open doors in 3D view
dexter303
How do i model or find a Door with adjustable opening precent in the 3D window. All familes that support adjustable door dont change in 3d....
Fri, Oct 21, 2005 at 4:41:18 PM | RE: Open doors in 3D view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
To model (easiest way to avoid errors and over complicating): Create an adjustable door panel (as a generic model) with all the required parameters. Nest it into another generic model family, link all the parameters and add a rotation parameter. Make sure you setup the origin to be at the hinge. Now load this into your door family, link the parameters and constrain the hinging point to an appropriate reference plane. You don't necessarily have to use this double nesting method but it avoids problems with constraining elements to the wrong things. HTH.
how to open family-doors in 3D?
Fri, Sep 22, 2006 at 1:12:30 AM
HOW TO OPEN DOORS DURING A WALK THROUGH
Wed, Aug 2, 2006 at 6:24:44 PM
How do I open doors in a walkthrough?
Mon, Apr 1, 2013 at 7:13:15 PM
Ceiling plan view... No Doors?
Wed, May 16, 2007 at 1:52:37 PM
Question, please
Fri, Dec 4, 2009 at 4:18:34 PM
Page generation time: 0.7213
