Forums >> Revit Building >> Technical Support >> Revit 2010 64 Bit
Mon, Oct 11, 2010 at 12:49:50 PM | Revit 2010 64 Bit
Nicolai
Are there other free PDF printers than cute pdf. Batcsplot function does not work on 64 bit
Nicolai
Mon, Oct 11, 2010 at 1:00:26 PM | Revit 2010 64 Bit
arusso5
www.pdf995.com
A free pdf driver.  It is an advertisement driver, so you have to click a button to 'continue using the free version' when you create the pdf, but it works just fine.  Not sure how the batch plot works with it... I've never tried that.
Mon, Oct 11, 2010 at 2:29:47 PM | Revit 2010 64 Bit
On cute's site, they say:
  • Added support for both 32-bit and 64-bit Windows 7.
  • Added support for both 32-bit and 64-bit Windows Vista.
  • Added support for 64-bit Windows XP/2003.
Tue, Oct 12, 2010 at 2:24:36 AM | Revit 2010 64 Bit
Nicolai
I have the new cute pdf and it only works when you plot one at a time. I haven’t tried the pdf995. I will try it and hope for the best. Thanks for the help
Tue, Oct 12, 2010 at 7:24:39 AM | Nicolai
gebber
gebber Avatar
5 Stars: 4 Votes
Quoting Nicolai from 2010-10-12 02:24:36
Same here thats why I use PDF Creator, it's slow but allows to have more sheets in a file.
Tue, Oct 12, 2010 at 1:23:12 PM | Revit 2010 64 Bit
TKennedy
4 Stars: 8 Votes
I've been using DoPDF, it seems to work ok.
Wed, Oct 13, 2010 at 11:46:40 AM | Revit 2010 64 Bit
pgalla
We use PDFILL on both 32 and 64 bit Windows 7
http://pdfill.com/
2010 and vista 32-bit
Thu, May 7, 2009 at 10:40:48 PM
11
Workshare monitor for 2010 64-Bit
Wed, May 6, 2009 at 12:37:39 PM
Export from Revit 2010 32 and 64 bit to Atlantis 2 available
Tue, May 26, 2009 at 11:34:30 AM
64 bit revit, 64 bit vista and multi-cores... [ 1 2 ]
Sat, Apr 4, 2009 at 1:38:57 AM
29
Revit 2010 to 3ds Max 2010 Problem
Thu, Jul 30, 2009 at 9:31:25 AM
Page generation time: 4.1010
