Forums >> Revit Building >> Technical Support >> Converting Autocad Layers to Standard Revit Linework
Sun, Oct 10, 2010 at 10:01:31 PM | Converting Autocad Layers to Standard Revit Linework
zoommby
I am using revit 2011.  In the earlier versions there seems to be talk of an Import/Export table for layer conversion.  I can only find export in 2011.  How can I set layers up in autocad so the lines become lines I have already defined in Revit?
Mon, Oct 11, 2010 at 7:35:32 AM | Converting Autocad Layers to Standard Revit Linework
Are you talking exploded or imported CAD?
Read this in your HELP: Setting Line Weights for Imported DWG or DXF Files
and...
For imported (linked) CAD, Manage Tab / Object Styles / Imported Objects.
Mon, Oct 11, 2010 at 11:19:59 PM | Converting Autocad Layers to Standard Revit Linework
zoommby
Thanks I really appreciate the help.
Fri, Nov 22, 2013 at 1:11:14 AM | Converting Autocad Layers to Standard Revit Linework
sachinweb
you can convert Autocad Layers to Standard Revit Linework by format conversion services. I downloaded Aide autocad to Revit Converter and Any revit Converter (http://www.formatconversion.biz), the programs worked great with converting.
AIA Standards- Revit to AutoCAD layers
Thu, Feb 1, 2007 at 12:50:29 PM
Revit Load Layers from Standard
Mon, May 2, 2016 at 2:28:08 PM
Changes to AutoCAD layers when imported to Revit
Wed, Oct 29, 2008 at 10:35:39 AM
[Frustration] How to separate Autocad layers in Revit?
Mon, Jun 25, 2012 at 11:31:55 AM
Importing Revit Layers into Auto CADD
Mon, Nov 19, 2007 at 8:09:11 PM
Page generation time: 2.1594
