Forums >> General Discussion >> Revit Project Management >> vector perspective export converts to parline?
Sun, Oct 10, 2010 at 6:51:24 PM | vector perspective export converts to parline?
LMAC
I'm trying to export a perspective view to manipulate in illustrator (exporting to AutoCAD dwg).
Problem is, it keeps converting my drawing to a paraline instead of perspective--?  I've tried directly exporting the view, and placing it on a sheet first, but same problem...
thanks for your help!
Mon, Oct 11, 2010 at 7:57:35 AM | vector perspective export converts to parline?
If you export the 3D model in Revit, you will get a true 3D model in CAD.  If you then want to see that in perspective, you will have to look at it that way in CAD.
If you placed a 3D perspective view on a sheet and export the sheet, it should be a 3D perspective but 2D linework in CAD.
Tue, Oct 12, 2010 at 9:09:38 AM | vector perspective export converts to parline?
LMAC
figured it out I think:  If I "print" (from sheet) to .pdf I get my image correctly in perspective--exporting to .dwg, revit converts the perspective to paraline
Converting to vector based file types
Sat, Mar 31, 2007 at 8:42:02 PM
Exporting Line Drawings
Thu, Sep 17, 2009 at 8:43:19 AM
Perspective Problem
Fri, Jun 26, 2009 at 12:13:43 PM
export to autocad
Wed, Jul 6, 2005 at 7:41:50 PM
Does Revit Render to 2D Vector?
Fri, Dec 13, 2013 at 6:52:44 PM
Page generation time: 2.8171
