Forums >> Revit Building >> Technical Support >> Family Files: Masking Regions and Nested Files
Fri, Oct 8, 2010 at 4:54:10 PM | Family Files: Masking Regions and Nested Files
SaraS01
We are building lighting fixture files with nested families so that they can be tilted.  When we add masking regions in our host files, they cannot tilt.  When we put them in our nested files, they do not show up when we insert our host file into a project file.
Does anyone know a way around this?
Thanks,
Sun, Oct 10, 2010 at 2:34:00 AM | Family Files: Masking Regions and Nested Files
mcantwell
mcantwell Avatar
Whatcha masking
Mon, Oct 11, 2010 at 7:34:36 AM | Family Files: Masking Regions and Nested Files
SaraS01
We are creating lighting fixture families.  All the instructions I've read, and Seek guidelines require that we make the actual 3D models of our lighting fixtures invisible in R/L, F/B, and Ref. views, replacing them with masking regions, looking like drafting symbols in these views.  We are masking anything below or on the wall behind the lighting fixture.
Perhaps I am misunderstanding the guidelines?
Mon, Oct 11, 2010 at 11:32:26 AM | Family Files: Masking Regions and Nested Files
lunchtrayrider
3.5 Stars: 7 Votes
this might be semantics but are the masking regions not showing up and therefore you can see the 3-d geometry or are the masking regions not showing up and therefore you can't see the lines around the edges of the masking regions? or?
-aaron
I like scooters. and motorcycles.
Mon, Oct 11, 2010 at 11:47:28 AM | Family Files: Masking Regions and Nested Files
SaraS01
You can't see the 3D geometry in any view except 3D, because it is turned off in the visibility settings.  You should only see the masking areas in R/L, F/B, and Ref. views, but you can see nothing at all when masking regions are in nested file instead of host file.  You can see the masking areas fine when they are made in the host file, but I cannot get them to work properly with the tilt parameter that we have build into the host file unless they come in via nested file.
Tue, Oct 12, 2010 at 5:53:01 AM | Family Files: Masking Regions and Nested Files
mcantwell
mcantwell Avatar
I got something to nest, tilt and mask, but without knowing what function you want it may be completely off target.
Tue, Oct 12, 2010 at 11:42:51 AM | Family Files: Masking Regions and Nested Files
SaraS01
Okay, I think that my colleague solved the problem.  I had initially nested a file without masking regions included.  I then went back and made the masking regions, saved the nested file and re-loaded into the host family.  Apparently, I needed to delete the old nested file and re-import it to make the masking regions work.  Sounds crazy, but it seems to work.
Thank you for trying to help.
Masking region do not mask as expected
Mon, Apr 29, 2013 at 8:34:59 PM
Masking Regions and Filled Regions - Which Is In Front?
Fri, Oct 28, 2011 at 2:26:55 PM
masking regions overlap other views in sheet?
Thu, Jul 7, 2016 at 11:14:07 AM
Exporting to Autocad with Masking Regions
Thu, Apr 25, 2013 at 10:33:27 AM
11
Revit 2010 Masking Regions
Mon, Nov 30, 2009 at 4:42:34 PM
Page generation time: 0.8916
