Forums >> Revit Systems >> Technical Support >> Different units for height and length
Fri, Oct 8, 2010 at 2:58:22 AM | Different units for height and length
tossaxe
Hello,Is it possible to make the Spot elevation show the value in meters while everything else releated stays in milimeters?
How coud this be done?
Fri, Oct 8, 2010 at 3:15:54 AM | Different units for height and length
tossaxe
Found it =)Here's how to do it on Revit 2009 if someone runs into the same problem:
1) Go to Settings=>Annotations=>Dimenssions. 2) Choose what you want to change (in my case it was "Spot elevation"Winking3) Under text select "Units format"4) Uncheck "Use project defaults" and customize as needed
'Inconsistent units" error in parameter formula; length vs integer
Fri, Dec 13, 2013 at 10:37:04 PM
Inconsistent units
Wed, Aug 11, 2010 at 8:17:26 AM
locking height of family to ceiling height?
Mon, Apr 27, 2009 at 5:29:03 AM
Conversion from English Units to Metric Units
Tue, Feb 17, 2009 at 4:32:52 AM
Adjusting the height and Length of a mass directly from the schedule ?
Fri, Jan 24, 2020 at 4:40:55 AM
Page generation time: 5.3791
