Forums >> Community >> Newbies >> Adding People To My Revit Rendering
Thu, Oct 7, 2010 at 8:26:33 PM | Adding People To My Revit Rendering
mrdamon
I'm somewhat new to Revit (loving it more and more), I just started to explore the rendering tools.  Does anyone know of some simple ways to add people to my Revit Renderings?  Should I just find some images and use Photoshop to add the people?  Any suggestions are welcomed.  (See attached sample).
Thanks.
mrDamon
Thu, Oct 7, 2010 at 9:16:42 PM | Adding People To My Revit Rendering
erland73
erland73 Avatar
4.5 Stars: 85 Votes
See the images attached.....You can buy RPC images from www.archvision.com, but they´re not cheap... You can also make your own. Read your HELP Menu.
83073_2010-10-072012.png83073_2010-10-072013.png83073_2010-10-072014.png83073_2010-10-072014001.png83073_2010-10-072015.png
Thu, Oct 7, 2010 at 9:17:35 PM | Adding People To My Revit Rendering
erland73
erland73 Avatar
4.5 Stars: 85 Votes
And the result........
Thu, Oct 7, 2010 at 9:45:59 PM | Adding People To My Revit Rendering
mrdamon
Thanks erland73.  i'll give this a try.
mrDamon
Thu, Oct 7, 2010 at 9:53:13 PM | Adding People To My Revit Rendering
nastyclown
nastyclown Avatar
4.5 Stars: 9 Votes
also, you can add people with a extrusion from people silouethe. There is a lot of that kind in Autocad format. Just bring that siloueths to an entourage family, add a thin extrusion ( lets say, 4 cms) and a semi-transparent material white. Just be sure to rotate all the extrusions facing to the actual camera... in large crowds that can be a real pain.
Fri, Oct 8, 2010 at 1:29:26 PM | erland73
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Your person is floating... Puh
Quoting erland73 from 2010-10-07 21:17:35
"And the result........"
Regards,
Chris.
Sun, Oct 17, 2010 at 2:44:23 AM | Adding People To My Revit Rendering
revittutorialsonline
i usually add people in photoshop post production. much better then the rpc rubbish.
Sun, Oct 17, 2010 at 4:01:38 AM | Adding People To My Revit Rendering
brianpcd
to User Menurevittutorialsonline
Curious of what package of People, Trees.....etc. you are using in Photoshop....?  Yes, getting burnt on the Archvision. They need to
work on their content, and also expand their horizons into VRay compatible objects.
Thanks, Brian
PCD
Sun, Oct 17, 2010 at 12:47:56 PM | Adding People To My Revit Rendering
mrdamon
To: revittutorialsonline,
Are you clipping people from stock photos or are you downlading people from a website and adding them to your renderings.  Great job by the way.
mrDamon
Sun, Oct 17, 2010 at 8:06:20 PM | Adding People To My Revit Rendering
The people and trees are from a library that I acquired, the people all have an alpha channel in photoshop so that you can select them nice and cleanly.
Fri, Oct 7, 2016 at 1:54:43 PM | Adding People To My Revit Rendering
uriepc
You might have AutoCAD Sketchbook Design, a program Autodesk throws in when you buy the AutoCAD Revit suite.
Produce the rendering in Revit. Export it (save it) in a JPEG format.
Open the JPG using Sketchbook Design ("Designer" not "Pro"). Import image you want to stick in the rendering. Locate and size it.
If you want to use an image that has background associated with it, first go on-line and subscribe to Clipping Magic ($4 a month at the present) and remove the background. Very east and fast. (Or you might be able to remove the background from the image using 2010 Word/Excel.) Clipping Magic saves the image in a PNG format. Works great.
Good luck.
help!...adding people to renderings.
Wed, Feb 23, 2005 at 7:15:41 PM
People for rendering
Wed, Dec 10, 2008 at 5:45:14 PM
rendering people
Thu, Nov 30, 2006 at 9:19:58 AM
Rendering People
Wed, Jan 9, 2013 at 2:41:25 PM
3D PEOPLE FOR RENDERING IN REVIT 2009
Mon, Feb 2, 2009 at 3:16:53 AM
Page generation time: 1.5192
