Forums >> Revit Building >> Technical Support >> Arrayed Array
Thu, Oct 7, 2010 at 4:09:26 PM | Arrayed Array
johnnyutah54
I just spent almost as much time thinking about how to phrase this question that I did playing with the family and I don't think that I am any closer to being coherent. Smile
 I am trying to create a grid of equally spaced elements based on overall width and length of the field. I have an array along the X axis that based on the 2nd item position (which I want as a parameter "panel width"Winking. I have then arrayed that array in the Y axis, based on the 2nd item position and the same distance ("panel width"Winking.
Everything works swimmingly until I attempt to change the panel width. The Y axis (the array of the original array) adjusts accordingly, but the X axis (original array) breaks. I can not figure out how to make that part work. When I try to edit the original array and lock the 2nd object to the refrence plane I set up (as I did the first time I made it) I can not align lock it at all.
 Any suggestions?
Thu, Oct 7, 2010 at 5:06:08 PM | Arrayed Array
TKennedy
4 Stars: 8 Votes
I haven't tried it, but what I would try is nesting the components you are arraying. Family 1 array on the x axis, nest that into Family 2 where you array Family 1 on the y axis. Create a parameter in Family 2 for the x axis number, then have that control the parameter inside Family 1.
Thu, Oct 7, 2010 at 5:20:21 PM | Arrayed Array
johnnyutah54
Thanks! I actually had come to that a moment before you responded. I tried it and it works perfectly. I always knew you "should" only array nested families, but now I will change my nomenclature to "shall" only array nested families or else it won't work right.
Thanks again.
Revit Structure 2012 Multiple Array Visibility
Tue, Jan 29, 2013 at 1:22:15 PM
Family Creation - Array number variable
Fri, Mar 12, 2010 at 1:15:31 PM
Array cut by void
Tue, Apr 6, 2010 at 4:53:52 PM
Can I have objects in a parametric array change height?
Fri, Sep 3, 2010 at 3:06:21 AM
Levels array
Wed, Feb 20, 2008 at 9:08:59 AM
Page generation time: 0.4481
