Forums >> Revit Building >> Technical Support >> linking a revit drafting view
Mon, Mar 22, 2004 at 9:24:36 AM | linking a revit drafting view
Bimman
Bimman Avatar
1 Stars: 2 Votes
i made a typicak wall section in revit. i want to link just the drafting view so i can make revisions from one place rather than having to fix revisions on 40 different typical wall sections. which is what happens when i would cut and paste 1 in each project. i can save the file out to a dwg. but my 2d software is microstaion and it flubs my wall section all up.
PWD
Mon, Mar 22, 2004 at 1:15:23 PM | RE: linking a revit drafting view
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
never done this but have you tried saving each detail as its own project file and linking to that? may be worth a try...
Hiroshi Jacobs
Mon, Mar 22, 2004 at 1:20:34 PM | RE: linking a revit drafting view
Bimman
Bimman Avatar
1 Stars: 2 Votes
THAT IS WHAT I DID TO START WITH, BUT I COULD NOT GET TO THE DRAFTING VIEW. SO I WENT ON AHEAD AND FIXED IT IN MICROSTION. THE BIGGEST PROBLEM WITH THE FILE IN MICROSTATION WAS TEXT STYLES BEING ALL MIXED UP. BUT ALL IS GOOD NOW AND I CAN DO ANY REVSIONS FROM THAT FILE SINCE IT IS LINKED INTO ALL OF MY MODELS. DO YOU LINK ANY FLAT DETAILS(2-D) INTO YOUR WORK. IF SO DO YOU USE AUTOCAD.
PWD
Sat, Apr 24, 2004 at 11:29:51 PM | RE: linking a revit drafting view
RCOLIN
I link all of my consultants autocad drawings since they don't use revit and haven't had any problems. I can turn off the layers I don't want and change the line weights to look correct for my drawings. That way if they update me with a new file I just have to copy over the old one. I have also linked in my own autocad drawings. For details I usually just import and explode them because there is usually always something different with each project.
Tue, Apr 27, 2004 at 8:54:12 PM | RE: linking a revit drafting view
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Just to save on switching between programs all the time have you thought of creating the typical wall section as a family detail component? That way you could edit it in revit and just reload the section if it is updated? At our office we find it easier to avoid linking DWG's for details as we have had quite a bit of trouble exporting views to DWG that contain linked DWG's. Hope this is helpful, Chris.
Regards,
Chris.
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Using a callout on a drafting view
Fri, May 16, 2008 at 10:39:58 AM
Linking drafting and detail viewz
Fri, Mar 3, 2006 at 3:13:50 AM
Would like to copy a drafting view from one project to another. [ 1 2 ]
Mon, Jan 4, 2016 at 6:07:17 PM
17
Rebars - Stirrups Tie in Drafting View
Wed, Aug 1, 2012 at 9:47:36 AM
Page generation time: 2.3772
