19 Users Online (17 Members):
Forums >> Revit Structure >> Technical Support >> Revit 2010 Extensions - Column Base Plate
i've been trying to figure out the base plate tool in extension manager, and so far think its brilliant, it seems to work really well and is really easy to use, but, for some reason im getting an error message (see attached) when i try and run it on certain columns. basically i was wondering if anybody else has this problem, reasons for this problem and how to solve this problem, any help would be appreciated. thanks
for anyone else suffering from this problem i figured out a short term fix, which is to apply the base plate to a column that works, still make it the correct size for the column you want it to go to. once its on the column, select the base plate and click on pick host and then select the column you want it attched to. it's solved the problem i was having but if anyone knows anymore about this i would like to hear about it.
97 Posts No Rating |
Do you know if this extension will work in Revit Architecture? We have in house structural engineers, but do not yet have a copy of Revit Structure. If we could use this extension that would be awesome. Thanks in advance.
Column base plate tag units display. |
Mon, Nov 17, 2014 at 2:24:40 PM
base plate visibility problem |
Thu, Dec 1, 2011 at 12:34:33 PM
Attaching a footing to a column with a base plate nested into the footing family |
Thu, Jul 11, 2019 at 12:23:42 PM
Column Base Plate Nested Family - GCS Visibility |
Sat, Feb 21, 2009 at 9:17:59 AM
Base Plates & Graphical Column Schedules |
Mon, Feb 22, 2010 at 11:51:01 AM
