Forums >> Revit Systems >> Technical Support >> I am having trouble loading the structural trusses
Thu, Oct 7, 2010 at 3:17:58 AM | I am having trouble loading the structural trusses
cachiro15
I have revit 2011 and i am having trouble trying to load the structural trusses everytime.
these are my steps 1) component 2) load family 3) strucural trusses. and then a little window pops up that says,
cannot load family files some or all of the family files you selected cannot be loaded. you must choose family files of the category component.
i can't even open the trusses that i downloaded from revit i don't have any trouble opening any other components except these please help!!
Thu, Oct 7, 2010 at 8:10:47 AM | I am having trouble loading the structural trusses
JAMESHGRIMES
JAMESHGRIMES Avatar
4.5 Stars: 10 Votes
That message usually means you are trying to load a family that is not of the category of the tool you are in. Try opening the Structural Tab and click on Truss. From there load your truss family and it should let you place it.
Thu, Oct 7, 2010 at 1:31:44 PM | I am having trouble loading the structural trusses
TKennedy
4 Stars: 8 Votes
You can also go to the Insert tab and use that Load Family tool. That one doesn't care what you are trying to load.
Thu, Oct 7, 2010 at 3:58:09 PM | I am having trouble loading the structural trusses
cachiro15
thanks for the help guys but what i did was i just opened the truss i downloaded from revitcity by itself and then i loaded it into project.
Structural trusses invisible when rendered in 3d camera vew
Sun, Oct 3, 2010 at 12:15:19 PM
Structural Trusses not attaching to walls
Fri, Dec 14, 2007 at 10:54:26 AM
Adding Trusses into Revit Project
Wed, Sep 21, 2005 at 3:02:13 PM
Strange orange lines in linked file
Mon, Sep 8, 2008 at 7:03:46 PM
Open Web Joist does not load
Mon, Feb 20, 2012 at 4:56:26 PM
Page generation time: 2.3410
