Forums >> Revit Building >> Technical Support >> Printing
Tue, Oct 5, 2010 at 3:03:26 PM | Printing
Westview
2.5 Stars: 2 Votes
Hello
I am having a problem when it comes to printing a PDF of a sheet. The problem is that it wont print to scale, it will always show the printable area as 96%. How can I change the printer limits to show 100%. This is not the case when I print on the plotter, the drawings print to scale. Has anyone eles had problems with PDF's not printing to scale?
Thanks, Ed
Tue, Oct 5, 2010 at 3:08:32 PM | Printing
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I assume you've checked the obvious in the Revit print settings and haven't got it set to "Fit To Page" and instead have it set to print to 100%?
If this isn't the cause, what PDF writer are you using as its clearly bodgy?
Regards,
Chris.
Tue, Oct 5, 2010 at 3:21:41 PM | Printing
Westview
2.5 Stars: 2 Votes
Thanks for the quick response.
I have checked all the settings and and they are the same as when I send it to the plotter. The problem is when I try to print from the PDF it shows the printable area as 96% of the sheet size.
Ed
Tue, Oct 5, 2010 at 3:39:40 PM | Printing
Westview
2.5 Stars: 2 Votes
Sorry I forgot to say I am using Primo PDF as a printer
Tue, Oct 5, 2010 at 3:43:30 PM | Printing
You don't really say what your printer settings are.  Are you using offset from corner or center plot?
CutePDF is free and works.
Tue, Oct 5, 2010 at 6:38:41 PM | Printing
Westview
2.5 Stars: 2 Votes
Thanks Mr. Spot for the help.
After checking every combination I was able to print to scale. I had to uncheck the pick PDF paper size and go into the properties and pick the ANSI paper size. The settings than showed 100%.
Thanks, Ed
Printing Problems Revit 2012
Wed, May 16, 2012 at 7:31:01 AM
Fill Region set to Transparent but printing Opaque [ 1 2 ]
Sat, Jan 26, 2019 at 12:16:15 AM
17
Printing Query
Wed, May 23, 2012 at 7:54:08 AM
Printing
Thu, Jun 14, 2018 at 12:59:04 AM
some keynotes not printing
Thu, Sep 15, 2016 at 4:43:39 PM
Page generation time: 1.9569
